GLCD connected to Atari XE - the first project with VIAtari
Done!
The first project which is using VIAtari was made...
I'm glad to present the first GLCD 162x64 connected to Atari:
Blank screen S1D15705 connected to Atari
In order to connect GLCD I used both parallel ports - PORTB is a data bus and PORTA is for control signals. Actually I used only 5 signals, so rest may be use for other stuff.
PCB of S1D15705
PCB of S1D15705
Detail regarding wiring you may find in attached software.
In this point I need to say thanks to @mono user from http://atari.org.pl which wrote very good PLOT procedure (topic: http://www.atari.org.pl/forum/viewtopic.php?id=16152).
Okay, showtime :-)
First test:
https://www.youtube.com/watch?v=AIqA3mwTjPE
Second test:
https://www.youtube.com/watch?v=UfRcnNq25qg
Pseudo"white noise" and fill test:
https://www.youtube.com/watch?v=Y7OI5nXIfd0
Plot test: (point by point into memory)
https://www.youtube.com/watch?v=A8FGVxnLplQ
The last 2 tests are making into Atari memory and result is sending as whole frame to CLCD. If you are interested in how it's work, please analyse software...
VIAlib111_cut.zip
Source code.
(17.89 KiB) Downloaded 40821 times
VIAxe.zip
KiCAD files with GERBERs
(345.84 KiB) Downloaded 40818 times
S1D15705 connected by VIAtari
